jokester4u
Junior Member level 2
- Joined
- Nov 26, 2013
- Messages
- 20
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 124
Does anyone know which software could be used to run the following code?
$regfile "M16DEF.DAT"
$crystal = 8000000
$baud = 9600
$hwstack = 32
$swstack = 8
$framesize = 40
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Up , Prescale = 8
Config Lcdpin = Pin , E = Portc.4 , Rs = Portc.5 , Db4 = Portc.3 , Db5 = Portc.2 , Db6 = Portc.1 , Db7 = Portc.0
Config Lcd = 16 * 2
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Config Timer0 = Counter , Edge = Rising
On Ovf0 Tim0_isr
Enable Interrupts
Enable Timer0
Tcnt0 = 0
Config Portc = Output
Dim A As Integer
Dim B As Integer
Dim C As Integer
Dim D As Single
Dim E As Single
Dim F As Single
Dim G As Single
Dim H As Single
Dim I As Single
Dim J As Single
Dim K As Single
Dim L As Single
Dim M As Single
Dim X As Single
Dim Y As Single
Dim Errr As Integer
Dim Ad As Integer
Dim Onn As Integer
Dim P_gain As Single
Dim I_gain As Single
Dim D_gain As Single
Dim Dt As Single
Dim Set_rpm As Integer
Dim Previous_error As Single
Dim D_error As Single
Dim I_error As Single
Dim Error As Single
Dim Feedback_rpm As Integer
Dim Otpt As Integer
Set_rpm = 0
Previous_error = 0
D_error = 0
I_error = 0
P_gain = 0.65
I_gain = 0.005
D_gain = 0.005
Dt = 0.5
A = 0
B = 0
C = 0
D = 0
E = 0
F = 0
H = 0
G = 0
I = 0
J = 0
K = 0
L = 0
M = 0
X = 0
Y = 0
Otpt = 0
Previous_error = Set_rpm - Feedback_rpm
Start Adc
Do
Set_rpm = Getadc(0)
Locate 2 , 1
Lcd Set_rpm
Tcnt0 = 0
Start Timer0
Waitms 500
Stop Timer0
A = Tcnt0
B = F * 255
C = A + B
D = C / 1
E = D * 5
E = E + 0
G = E
Feedback_rpm = G
X = Set_rpm - 2
Y = Set_rpm + 2
If G > X And G < Y Then
G = Set_rpm
End If
Cls
Locate 1 , 1
Lcd G
F = 0
Error = Set_rpm - Feedback_rpm
H = Error * Dt
I_error = I_error + H
I = Error - Previous_error
D_error = I / Dt
J = P_gain * Error
K = I_gain * I_error
L = D_gain * D_error
M = J + K
Otpt = M + L
Previous_error = Error
' Errr = Set_rpm - Otpt
Onn = Onn + Otpt
If Onn > 254 Then
Onn = 254
End If
Compare1a = Onn
Loop
Tim0_isr:
F = F + 1
Return
End
Explanation of main course of program:
Config Lcd = 16 * 2
On Ovf0 Tim0_isr
Timer 0 is configured as counter which counts the input pulse from the sensor.
Timer 1 is configured as PWM to give the output signal to the L298n.
Lcd and adc is also configured.
Start Timer0
Waitms 500
Stop Timer0
A = Tcnt0
Timer is started to count the pulse for every 500 ms.
Value is stored into variable A.
A = Tcnt0
B = F * 255
C = A + B
D = C / 1
E = D * 5
E = E + 0
G = E
Conversion of pulses into rpm
Feedback_rpm = G
X = Set_rpm - 2
Y = Set_rpm + 2
G = Set_rpm
End If
Cls
Locate 1 , 1
Lcd G
F = 0
H = Error * Dt
D_error = I / Dt
J = P_gain * Error
M = J + K
Otpt = M + L
Onn = Onn + Otpt
