AT89S52 Newbie (need self made USBasp programmer charts)
diablodoro
Newbie level 3
Newbie level 3
Hello
Im starting to learn how to program AT89S52 and i was wondering can some one give me a simple charts to build a programmer for my self
a have USBasp cable and i wish to use it for my programing
if some one can give me good advice im happy to read it :)
10x alot :)
i am having project downloaded from net. but i not tested it, here iam uploading the schematic & firmware it supports 89s52 & atmega
  • usbasp-windriver.2009-02-28.zip
i dont see your upload
im looking for way to connect the USBasp whit the AT89S52
i had some problems whit connecting the USBasp to my Laptop but i fix it
i try this https://www.thierry-lequeu.fr/data/ISP-USB-5.jpg
but i get error on reading the microcontroller ( i used Resistors too )
my USBasp https://d1gsvnjtkwr6dd.cloudfront.net/large/AC-PG-USBASP_LRG.jpg
IF you use a usb based programmer you need a pre programmed controller before you making your programmer :cry:
Other wise you can make programmer to burn controller(8051) through direct parallel port
and available the circuits in web
i make the programmer work i used 20 SJK instead of SJK 8 now everything work im looking for termenal for the programmer :)
Congrats on your success.. I too need the exact way how to program AT89S52 using the same USBASP..
I referred the image you posted.. Do I need to connect the programmer, as it is in the image?? Were there any modifications you made??
I didn't understand what's "used 20 SJK instead of SJK 8 now everything work"??? Which frequency crystal oscillator did you use and are the capacitors 30pF only??
Thank you..
