AT89S52 and ISP Programming
kabaza
Junior Member level 3
The circuit has to be built exactly as it is on the schematic diagram ( file: SCHEMATIC.pdf ).
As you can see, the microcontroller will be connected to Vcc via transistor Q1 ...
It will happen automatically, when the software is running ...
:wink:
IanP
Reactions: kabaza
    kabaza
transistor bc557 == the voltage regulator 7805?
---------- Post added at 14:39 ---------- Previous post was at 14:05 ----------
Also all I got is crystal 11.059 MHZ is that ok?
1) the whole circuit should have regulated 5V, so using 7805 should be OK.
You still though need Q1 as the Vcc switch ..
2)11MHz clockl will be to fast; these programmers use 4MHz crystals ..
:wink:
IanP
:wink:
IanP
Thnx for your help but I setup the circuit as shown above. But when I try to erase/program at89s52 I get this screen
use follow connection with the avr isp.
any help?=/
Thanx
more info !
Try reducing the programming speed.
