AT89S52 7 segment multiplexing along with IR - RC5 decoding !!
rajesh279
Junior Member level 3
Hello All,
I am currently trying to execute logic for 7 segment multiplexing along with RC5 decoding from IR TSOP1738 sensor.
The 7 segment multiplexing is taken care by Timer 0 ISR (10 ms duration) whereas RC5 decoding is done using Timer 1 delay routines.
The approach is shown in below code. The problem I am facing is, whenever I press any remote button, the multiplexing get disturbed while decoding IR signal.
Overall, I would like to understand how both multiplexing and IR decoding can be done together without disturbing each other, as both are time dependent event.
#define IR_Signal P3_2
void delay() //delay of 1.664msec
        TMOD=1;
        TL1=0x02;
        TH1=0xFA;
        TR1=1;
        while(TF1 == 0);
        TR1=0;
        TF1=0;
void delay3() //delay of 2.75 bits = 2.75*1.664msec = 4.57 ms
        TMOD=1;
        TL1=0x86;
        TH1=0xEF;
        TR1=1;
        while(TF1 == 0);
        TR1=0;
        TF1=0;
void InitTimer0(void) //Init Timer 0 for 10 ms multiplexing
EA=0;
TMOD = 0x01;
TH0 = 0xDC;//
TL0 = 0x00;
TR0 = 1;
ET0 = 1;
EA = 1; //Enable Global interrupt
int main()
InitTimer0();
if(IR_signal == 0) // IR signal received on micro-controller pin, collect remaining 11 bits in interval of 1.664 ms
        cmd=0;
	val=0;
        for(i=0; i<12; i++)
            val=(val<<1) | input;
            delay();
		cmd = val & 0x3F; //command received from Remote control
return 0;
Ok, now i will present my whole code here. I can understand that because of use of Timer 0 in all the places, I might be facing the problem, but I could not get the workaround on this.
unsigned char cmd=0,val=0;
void delay() //delay of 1.664msec  //delay of 1.658msec
        TMOD=1;
        TL0=0x02;
        TH0=0xFA;
        TR0=1;
        while(TF0 == 0);
        TR0=0;
        TF0=0;
        TMOD=1;
        TL0=0x86;
        TH0=0xEF;
        TR0=1;
        while(TF0 == 0);
        TR0=0;
        TF0=0;
void InitTimer0(void) //Init Timer 0 for 5 ms multiplexing
EA=0;
TMOD = 0x01;
TH0 = 0xEE;
TL0 = 0x00;
TR0 = 1;
ET0 = 1;
int main()
InitTimer0();
    while(1)
                delay3(); //wait for 2.75 bits = 4.57 ms
                cmd=0;
	        val=0;
                for(i=0; i<12; i++) //collect 11 bits and segregate last 6 command bits
                    delay();
return 0;
void timer_0ISR () interrupt 1
Multiplexing_Logic(); //activating 1 column at a time and sending data to shift registor
Really? I don't see interrupt enable for timer0 set in your code. So how timer interrupt is supposed to work at all? Likewise timer1 is only used in polled mode, so how would it affect timer0 interrupt operation?
Interrupt is enabled for Timer 0 as : ET0 = 1;
Timer 1 is not used in Polled mode. Please see my latest code. Timer 0 is used in polled mode.
Regards,
Raj S.
Right, I wasn't aware of the meaning of ET0.
O.K. I thought Timer1 would be used for the delay, according to the description in post 1. But you are using timer 0 both for interrupt and delay which can't work.
I see another strange thing in the code, why are you returning from main()?
Please find my attached whole code.
Somehow decoding IR signal is not correct and multiplexing not working properly.
Please provide Your suggestion on how to resolve it.
Thanks.
  • main.txt
in your code MasterDisplay(dataseg); using in main on each timer 1 over flow MasterDisplay(dataseg); is interrupt
by timer ISR() for display use timer 0 and set timer 0 IP high
