Register Log in
at89s ISP programming
freakkaito
Member level 1
hey bro, i want to program an at89s via ISP, not from computer but i want to use avr as master:
AVR (ATmega32) <==ISP==>AT89S
MASTER ........................................................SLAVE
ATMEGA32......................................................AT89S
MOSI | <----------------------------------------> | MOSI
MISO | <----------------------------------------> | MISO
CLK | <------------------------------------------> | CLK
what should I do, i've send the enabled data but i never get the respon. can anyone help me
nandhu015
Advanced Member level 5
India
what about reset pin of 89s52?
nandhu
    freakkaito
laktronics
Banned
You have to put S51 in reset mode. Select an SCK clock slower than 1/16 th of S51 clock. Keep SCK low for atleast 64 clock cycles before issuing the commands. And use mode 0 SPI master. I think with these, you should be able to program S51.
Regards,
Laktronics
Added after 2 hours 33 minutes:
Also use MSB first logic.
Regards,
Laktronics
    freakkaito
freakkaito
Member level 1
by your sugest, i've made this source. my ATmega32 clock is 4Mhz and AT89s 16Mhz so i can using 1Mhz transfer clock (1/16 at89s clock). reset is set on high position.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <avr/pgmspace.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "global.h"
#include "lcd.h"
#define SPI_USEINT
int targetInit(void);
void targetClear(void);
uint8_t spiTransferByte(uint8_t data);
volatile u08 spiTransferComplete;
void spiInit(void);
int main (void)
#ifdef SPI_USEINT
SIGNAL(SIG_SPI)
spiTransferComplete = TRUE;
#endif
lcd_init(LCD_DISP_ON);
spiInit();
start:
if(!targetInit())
lcd_gotoxy(0,1);
lcd_puts("Target Error");
delay1s();
goto start;
else
lcd_clrscr();
lcd_puts("target ok");
targetClear();
_delay_ms(100);
spiTransferByte(0xAA); //write 0xAA to target
spiTransferByte(0xac);//send first byte
spiTransferByte(0x53); //send second byte
spiTransferByte(0); //send 3rd byte
if(spiTransferByte(0)==105) //the respon should be 105 decimal or 69 hex
return(1);
else
return(0);
spiTransferByte(0xac); //target clear instruction
spiTransferByte(0x80);
spiTransferByte(0);
spiTransferByte(0);
#ifdef SPI_USEINT
spiTransferComplete = FALSE;
outb(SPDR, data); // send data
while(!spiTransferComplete);
#else
while(!(inb(SPSR) & (1<<SPIF))); // wait until finish
#endif
return inb(SPDR); // get the return data
void spiInit(void)
sbi(PORTB, 7); // set SCK hi
sbi(DDRB, 7); // set SCK as output
cbi(DDRB, 6); // set MISO as input
sbi(DDRB, 5); // set MOSI as output
sbi(DDRB, 4); // SS must be output for Master mode to work
// setup SPI interface :
sbi(SPCR, MSTR); // master mode
cbi(SPCR, SPR0); // clock = f/4 ------> 4/4=1Mhz
cbi(SPCR, SPR1);
cbi(SPCR,DORD); // MSB first
sbi(SPCR, SPE); // enable SPI
inb(SPSR);
// enable SPI interrupt
sbi(SPCR, SPIE);
but i never get the response. or my programe code is wrong?. i use lcd 16x2 as a display and winavr as compiler.
laktronics
Banned
1. How do you put 89S51 in Reset mode?
2. How are you setting Mode0 In SPI?
3. You have set SCK high to start with, in mode zero, idle state of SCK has to be low
After putting S51 in reset, you have to wailt for about 64 CPU clock cycles before giving commands. I am sorry, I will not be able to help you with coding.
Regards,
Laktronics
freakkaito
Member level 1
oh yeah, that's my old code. this the new one:
cbi(PORTB, 7); // set SCK low
cbi(SPCR, SPR1);
cbi(SPCR,CPHA); //transmision mode 0
cbi(SPCR,CPOL);
inb(SPSR);
sbi(SPCR, SPIE); // enable SPI interrupt
that the spi init code, answering your question:
1. i put the AT89s always in reset, from the biginning the reset pin is connected with vcc, coz the project board only for external programing so i think that's not a problem.
2. mode 0 SPI, i set the CPHA and CPOL register by zero.
3. yeah my first code show that i put the sck on high, that's my mistake.
by the way even i already fix the code, i not get the response.
my friend sugest me to use ordinary I/O port coz the tranfser logic only using sift register, and we make this code:
uint8_t spi_transfer (uint8_t data)
unsigned char tempA,tempB,temp1,temp2,count;
unsigned char data_transmit, data_recieve,recieved;
data_transmit=0;
data_recieve=7; //MSB first
recieved=0;
tempA=0;
tempB=0;
temp1=0;
temp2=0;
cbi(DDRD,0); // set PORTD0 as miso input
sbi(DDRD,1); // set PORTD1 as mosi output
sbi(DDRD,2); // set PORTD2 as SCK
cbi(PORTD,2); // set SCK low
for(count=8; count>0; count--)
tempA=data;
tempB=(tempA<<data_transmit);
if((tempB)&0x80==80)
sbi(PORTD,1);
else
cbi(PORTD,1);
sbi(PORTD,2); //sck high
delay_ms(50); //wait for some times
cbi(PORTD,2); //sck low
temp1=PIND; //get the response bit
temp1=temp1&0x01;
temp2=(temp1<<data_recieve);
recieve=temp2 | temp1;
data_transmit++;
data_recieved--;
return recieve;
and when i send the enabled data i not get the response too. what must i do? is there anyone could help me with some code, coz i stil newbie here...
nandhu015
India
freakkaito
atmega 32 port pins have stronger pullups. I think 89s dont have power to pull it down please check it out
Nandhu
laktronics
Banned
In your code, you have to pick up MISO bit when clock is high. Please see below a suggested SPI code. You should be able to take care of all coding requirements. I am not a dependable source for codes.
uchar spi_transfer(uchar data)
// change the following bit definitions as per your compiler requirements
sbit miso = (PortD,0);
sbit mosi = (PortD,1);
sbit sck = (PortD,2);
unsigned char count;
If(data&0x80)
MOSI = 1;
Else
MOSI = 0;
data<<1;
sck = 1;
delay();
If (miso)
data = data+1;
sck = 0;
return data;
Regards,
Laktronics
    freakkaito
ctownsend
Advanced Member level 2
Canada
Perhaps the SPI mode you have set up with the avr is incorrect.
Check the datasheet for the 89S51.
I have done this with another 89S51 (as master) using bit-bang spi routines in the 89S51.
Look here:
https://www.edaboard.com/viewtopic.php?t=283581&highlight=
it may give you some ideas.
I do have some parts of this programmer done with avr code, however it is not complete.
Good Luck
    freakkaito
freakkaito
Member level 1
thank you very much guys, you realy help me this time. I'll try to fix my source and use Laktronics source, i hope it's can work.
and for ctownsend, i already have your code, i not really great with asembly but thank's very much that realy great project.
wish me luck ok!
freakkaito
Member level 1
hey guys, i did it!!!!!! i get the response....
Laktronics thank you very much, you right i have to read miso pin when the clock still high.
horeeeee
laktronics
Banned
Thanks for the feedback and congrats. You can now try programming the chip.
Regards,
Laktronics
    freakkaito
Toggle Sidebar
