AT89C2051 not working URGENT
amayilsamy
Advanced Member level 1
Chennai,India
I'm using AT89C2051 for small function..
I post My code and schematic.. it is working Proteus in my circuit is not worked.
  #include<reg51.h>
  sbit led = P1^7;
  sbit sw  = P1^6;
  int i,a;
  void delay(unsigned int ms) ;
  void main()
			P0=0x00;
			while(1)
			  P1=0x00;
//			led  = 1;
//			sw   = 0;
			delay(10);
//			led  = 0;
//			sw   = 1;
			P1=0xff;
			delay(1);
			for(a=0;a<=5;a++)
					for(i=0;i<=10000;i++);
  • 2051.pdf
I changed delay(10000) and removed the lines P1=0x00; P1=0xff; Again its not work..
And I also see the output in scope..
And I power up the controller all pins in high (4.85 V) except P1.1,P1.0.
I try to low the all port pins its doesn't work.
void main()
while(1)
P1=0x00;
P3=0x00;
Maybe it is a problem with Proteus 89C2051 model. Try in hardware. Are you sure you have included the right device header file in the code?
Copy paste this hex data to a txt file and save it as .hex file and use this file and see if it works.
:03000000020003F8
:0C000300787FE4F6D8FD7581070200004C
:00000001FF
hello,
while you program the ic , open and see the hex file is there some program , because in some compiler hex for 2051 will not be produced . or you could check this same code with 4051. once i had also got a problem like this my compiler was not producing proper hex file.
