at80c51 thermometer project
beyaz
Newbie level 5
at89c51 thermometer project
Hey guys i have to do project about thermometer as using at 89c51 microchip.
i need a circuit design and code for this project.:!:
if anyone know plz post here.
thanks
use ds1820 or ds18S20 for the project, u can get alot of resources if u search for the sensor interface to 89c51
i have this file but its with avr ,regarding the hardware u just need the ds18x20 sensor, a few resistors, a LCD and a microcontroller ..
You can search for the ds18x20 library for your microocntroller and use it!
Reactions: beyaz
    beyaz
i have to with at89c51 otherwise i get zero points from project
:cry:
---------- Post added at 09:36 ---------- Previous post was at 09:32 ----------
i have dallas 18b20 atm as sensor
you can get lots of code out there ... the code is in C usually so u can port it to 89c51 if its not for that! what have u done so far?
if its a college project u should do it your self instead of getting a ready made code +hardware diagrams
if you wanna learn start searching here at edaboard or u may visit 8051projects.net find some code , and then if u have any problems or anything u don't understand we are here to help
The real problem is im computer engineer student.Maybe if i push myself i can do code but i realy dont understand about circuit design.i need that.i will keep up to search but if anyone knows it help me a lot.
---------- Post added at 09:48 ---------- Previous post was at 09:47 ----------
use LM35 sensor and 89c51 controller and ADC and LCD for your project.
As i know dallas 18b20 is digital sensor isnt that more easy?
ty i also find this one
That's a nice one, although you have to add a ADC chip as 89c51 doesn't have ADC.
can you give circut diagram
By the way, are you familiar with I2C serial EEPROM as 24C16 or 24C512 etc...
Could you download the datasheet of DS1721 (8-pin)?
Is the IC available for your project?
The circuit is very simple (like interfacing with 24Cxx). Two pins from the MCU will be connected to two pins on the IC. I usually add two pullup resistors (one for each pin) of value 10K (or 4k7) to get a better rise time.
Kerim
Hey again guys i need to convert c code to hex;
here is the code;
#include<reg51.h>
#define port P3
#define adc_input P1
#define dataport P0
#define sec 100
sbit rs = port^0;
sbit rw = port^1;
sbit e = port^2;
sbit wr= port^3;
sbit rd= port^4;
sbit intr= port^5;
int test_intermediate3=0, test_final=0,test_intermediate1[10],test_intermediate2[3]={0,0,0};
void delay(unsigned int msec )
int i ,j ;
for(i=0;i<msec;i++)
for(j=0; j<1275; j++);
void lcd_cmd(unsigned char item) // Function to send commands to LCD
dataport = item;
rs= 0;
rw=0;
e=1;
delay(1);
e=0;
return;
void lcd_data(unsigned char item) // Function to send data to LCD
dataport = item;
rs= 1;
rw=0;
e=1;
delay(1);
e=0;
return;
void lcd_data_string(unsigned char *str) // Function to string to LCD
int i=0;
while(str!='\0')
lcd_data(str);
i++;
delay(10);
return;
void shape() // Function to make the shape of degree symbol
lcd_cmd(64);
lcd_data(2);
lcd_data(5);
lcd_data(2);
lcd_data(0);
lcd_data(0);
lcd_data(0);
lcd_data(0);
lcd_data(0);
void convert() // Function to convert the values of ADC into numeric value to be sent to LCD
int s;
lcd_cmd(0x81);
delay(2);
lcd_data_string("TEMP:");
test_final=(((9*test_intermediate3)/5)+32);
s=test_final/100;
test_final=test_final%100;
lcd_cmd(0x88);
if(s!=0)
lcd_data(s+48);
else
lcd_cmd(0x06);
s=test_final/10;
test_final=test_final%10;
lcd_data(s+48);
lcd_data(test_final+48);
lcd_data(0);
lcd_data('F');
lcd_data(' ');
test_final=test_intermediate3;
lcd_cmd(0xc1); //Setting cursor to first position of first line
delay(2);
s=test_final/100;
lcd_cmd(0xc8);
if(s!=0)
lcd_data(s+48);
else
lcd_cmd(0x06);
s=test_final/10;
lcd_data(s+48);
lcd_data(0);
lcd_data('c');
lcd_data(' ');
delay(2);
void main()
int i,j;
adc_input=0xff;
lcd_cmd(0x38); //2 Line, 5X7 Matrix display
lcd_cmd(0x0c); //Display On, Cursor blinking
delay(2);
lcd_cmd(0x01); // clear screen
delay(2);
while(1)
for(j=0;j<3;j++)
for(i=0;i<10;i++)
delay(1);
rd=1;
wr=0;
delay(1);
wr=1;
while(intr==1);
rd=0;
lcd_cmd(0x88);
test_intermediate1=adc_input/10;
delay(1);
intr=1;
for(i=0;i<10;i++)
test_intermediate2[j]=test_intermediate1+test_intermediate2[j];
test_intermediate2[0]=test_intermediate2[0]/3;
test_intermediate2[1]=test_intermediate2[1]/3;
test_intermediate2[2]=test_intermediate2[2]/3;
test_intermediate3=test_intermediate2[0]+test_intermediate2[1]+test_intermediate2[2];
shape();
convert();
i used micro c but it didnt work it said 0 304 C:/Users/Ucdemir/Documents/omer.c:1: error: Can't open include file "reg51.h"
can anyone help me which compiler converter i can use to convert c to hex
---------- Post added at 15:17 ---------- Previous post was at 13:46 ----------
up.....
need help
ty so much
---------- Post added at 15:58 ---------- Previous post was at 15:51 ----------
There are :cool:
i afraid if you copy like that hex file is wrong ?
i have suspicion.where did you get code ?
here
or by my writing?
also ty for helping
i appreciate you.
but im like newbie.
can you teach me how can i also do as using this program
ty
