dandygal
Newbie level 3
- Joined
- May 17, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,314
I need to design a systems using Xilinx Schematics with the following specifications:
This combination lock has a minimum sequence of four two-bit input symbols as the combination
and appears to the user as if it is an asynchronous circuit. Actually, it is a synchronous circuit
with a fast clock and synchronization of the user inputs. For a given input combination, the circuit
goes to a state and cycles there until the input changes to a new symbol; thus, the combination
cannot contain consecutive appearances of the same symbol. The lock is locked by using an
asynchronous RESET.
Here is a sample implementation of the problem:
I need to understand the logic behind it. Can you explain me whatever you can make out from this information?
Thanks,
asynchronous RESET.
Thanks,
