Hello everyone!
I have no ASIC experience, but FPGA one only. I have one question regarding ASIC. Let's say I have a negative-active reset with asynchronous assertion and synchronous deassertion. As I understand it's totally safe to connect this reset to a FF's synchronous reset input. Do you agree? My arguments:
1). Asynchronous assertion is not a problem for both asynchronous and synchronous inputs, because the reset has a long duration.
2). Even if a clock is not active during the whole reset, such a FF will be reset anyway, because the presence of the clock in the end of the reset sequence for synchronous deassertion guarantees at least several clocks (corresponding to a number of FFs in the reset synchronizer) of synchronous-like reset pulse (0 was set long time ago and it's sampled synchronously at the fist clock appeared and then/ a few cycles LATER, 1 is sampled synchronously).
