After renew the license, I run the Assura RCX with error. (DRC and LVS are alright) But it is only happened in sparc Solaris machine, it is alright in x86 Linux machine. I use same layout to do the test. Both Linux and Solaris use IC5141 and Assura3.1.7. Please help!
RCX Error message
Assura (tm) Physical Verification Version av3.1
roduction:dfII5.1.41:5.10.41.500.4.66
Release 3.1.7_USR2
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av3.1
roduction:dfII5.1.41:5.10.41.500.4.66 02/05/2008 06:51 (sfsol121) $
sub-version 3.1.7_USR2, integ signature 2008-02-03-1403
run on mach02 from /cadence/assura/tools.sun4v/assura/bin/32bit/assura on Mon Apr 14 19:06:53 2008
Error: ?netNameSpace is an unrecognized rcxParameter in the DFII flow.
Error: ?maxFractureLength is an unrecognized rcxParameter in the DFII flow.
Error: ?fractureLengthUnits is an unrecognized rcxParameter in the DFII flow.
Error: ?temperature is an unrecognized rcxParameter in the DFII flow.
Error: ?capExtractMode is an unrecognized rcxParameter in the DFII flow.
Error: ?capGround is an unrecognized rcxParameter in the DFII flow.
Error: ?capCouplingFactor is an unrecognized rcxParameter in the DFII flow.
Error: ?type is an unrecognized rcxParameter in the DFII flow.
Error: ?rcxfsType is an unrecognized rcxParameter in the DFII flow.
Error: ?minR is an unrecognized rcxParameter in the DFII flow.
Error: ?maxMergedViaSize is an unrecognized rcxParameter in the DFII flow.
Error: ?arrayViasSpacing is an unrecognized rcxParameter in the DFII flow.
Error: ?capModels is an unrecognized rcxParameter in the DFII flow.
Error: ?parasiticCapModels is an unrecognized rcxParameter in the DFII flow.
Error: ?resModels is an unrecognized rcxParameter in the DFII flow.
Error: ?parasiticResModels is an unrecognized rcxParameter in the DFII flow.
Error: ?parasiticResWidth is an unrecognized rcxParameter in the DFII flow.
Error: ?parasiticResWidthDrawn is an unrecognized rcxParameter in the DFII flow.
*WARNING* Technology dir /export/program/cadence/CIC_ptfm_Analog_102903/FLOW_GPDK18/share/lib/gpdk_dbv1p9/assura_gpdk_tech is used more than once
Errors exist in master control file "/home/david/lab/rcx.inv.rsf".
***** Assura terminated abnormally *****
