Hi
I ma trying to re simulate an extracted design and getting strange results. It is acting as if all the inputs and outputs of sub blocks are floating and their is no interconnection between sub blocks.
Background:
I have tried extract and simulate one level say an inverter and it works fine but when I try a higher level design say two inverters back to back it acts as if they are not connected. I did get it to extract and simulate properly when I do c only but fails when you add r parasitic exaction.
One form I found said to try
setenv DBGRCX_CONNECTIVITY Y
and run Icfb.
With this set I get the flowing error when I try and extract r parasitics:
cat <<ENDCAT> gemfilterfile
F model=C 2 X X
ENDCAT
gemini -V -S -w -td 0.01 -flt gemfilterfile -ac"C" -prr_c '#' -f_name_io \
s#vdbToRcx.sp s#/data1/jmoore/lvs/test1/extview.tmp
Incorrectly built binary which accesses errno or h_errno directly. Needs to be f
ixed.
INFO (GEMINI-113014): gemini: Declaring node 0 as global - default.
Removed parasitics in test_two_to (resistors: 30 -> 0, L-inductors: 0 -> 0, VCCS
: 0 -> 0)
INFO (GEMINI-113236): THE DESCRIPTIONS ARE DIFFERENT,
INFO (GEMINI-113230): test_two_to & test_two_to
GEMINI COMPARISON CONCLUDES:
The circuits do not match.
INFO (GEMINI-113292): Gemini: Reading files took
INFO (GEMINI-113184): 0.00 user, 0.00 sys, 0.00 elapsed, 135.2 Kbytes
INFO (GEMINI-113293): Gemini: Comparison took
ERROR (LBRCXM-609): Bad return status from RCX run. 0x100
INFO (LBRCXM-709): ***** QRC terminated abnormally *****
This problem started after upgrading our design kit and Assura.
we are using IBM: cmrf8sf V1.7.0.2DM or V1.8.0.1DM/ (fails with booth)
Assura (tm) Physical Verification Version av4.1
roduction:dfII6.1.3:IC6.1.3.500.10
Cadence Extraction QRC - Parasitic Extractor - Version 9.1.4-p008 Thu Nov
