bodenste
Newbie level 2
I have the following situation and am uncertain how to proceed:
* Input voltage 0V to 5V (single ended signal)
* Output voltage: differential output, 2V p-p
I have a fully differential op amp that I believe is set up correctly (Rf = 400, Rg = 1k, Vocm = 2.5V, +5V rail and ground rail).
If I input +2.5V to -2.5V I get exactly the correct output :
* Vin@ 2.5V -> Vout+ = 3V Vout- = 2V
* Vin@ 0V -> Vout+ = 2.5V Vout- = 2.5V
* Vin@ -2.5V -> Vout+ = 2V Vout- = 3V
However, I do not have Vin = 2.5V...-2.5V. I have Vin = 0...5V.
What is the best way to adjust my input voltage? Do I need an additional op amp? I do not currently have a negative voltage rail but I suppose I could create one using a charge pump IC.
Is there some other clever way to accomplish this?
Thanks!
Thanks!
