Assembly program question
sagar474
Full Member level 5
India,kakinada
BITS 16
	mov ax, 07C0h		; Set data segment to where we're loaded
	mov ds, ax;
	mov ax,9999
	mov ss,ax
	mov sp,0000h;
test_string db 'Test' ; it prints a if these two lines are erased
mov si,test_string
;----------------------to print 'A' --------------------------------------------
	mov al,41h
	mov ah,0eh;
	int 10h;
	jmp $; jump hear ie., infinite loop
times 510-($-$$) db 0	; Pad remainder of boot sector with 0s
	dw 0xAA55		; The standard PC boot signature
this program should print A bit it prints dose nothing
help
please
FvM
Super Moderator
Staff member
Bochum, Germany
You have placed the string inside your code, so the processor will try to execute the data as instruction. It should be place somewhere else, e.g. after jmp $..
