[SOLVED] array fillup problem
nsgil85
Member level 4
hello you all,
I'm trying to simulate TB that fills series in array of unsigned numbers.
I can't figure out why i get only zeros in this array bellow:
Code VHDL - [expand]
8
9
10
11
12
13
signal  helper_add_values_to_display_array  : integer range 0 to ((2**simulation_GENERIC_POS_CONF_DISPLAY_DATA_WIDTH) -1) := 0 ;
begin
process_fill_up_display_array:  process
                                    begin
                                    loop_arry: for y in 0 to simulation_GENERIC_POS_CONF_NUMBER_OF_ROWS -1 loop
                                                    simulation_PORT_IN_UNS_ARRAY_DATA_TO_DISPLAY(y)     <= to_unsigned(helper_add_values_to_display_array, simulation_PORT_IN_UNS_ARRAY_DATA_TO_DISPLAY(y)'length);
                                                    helper_add_values_to_display_array                  <= helper_add_values_to_display_array +1;
                                               end loop loop_arry;
                                    wait ;
                                end process ;
(i know i can put "y" instead of "helper_add_values_to_display_array" and solve it but i wonder what is the problem)
thank you :lol:
You need to learn about the behaviour of signals and processes. helper_add_values_to_display_array is only updated once at the end of the process, it keeps it's previous value of 0 during the loop iteration and is assigned 1 afterwards.
You can use a variable if you want immediate update.
