Emati
Newbie level 2
- Joined
- Feb 13, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 12
Hello,
I am bigginer at designing array antenna.:sad:
I designed a vivaldi array antenna 1*4 in CST. I have some problems: 1) How can I see the radiation pattern of array antenna ,not each element?
2)I design a antenna with waveport then copy the antenna and waveport 3 times that gave me a array 1*4, what did i do is correct? the waveports have to be simultaneously? if yes how can i do it?
could you please guide me if i want to use power divider for feeding , what should i do? should i design a power divider in cst separately then import it in cst file that my array is there?
Regards
Regards
