ARM SAM3S Compilling Error
yokohama
Member level 3
Member level 3
Algeria
Hi All,
This day, I'm trying with ARM microcontrollers (AT91SAM3S2B), and have an error when compilling.
I'm using SAM3-P256 dev board from Olimex, Eclipse + Yagarto and the file for blinking a led is lisled below.
this demo software is from Olimex.
* Headers
#include "board.h"
#include <stdbool.h>
#include <stdio.h>
* Local definitions
/** IRQ priority for PIO (The lower the value, the greater the priority) */
#define IRQ_PRIOR_PIO 0
/** LED0 blink time, LED1 blink half this time, in ms */
#define BLINK_PERIOD 1000
* Local variables
/** Pushbutton \#1 pin instance. */
const Pin pinPB1 = PIN_PUSHBUTTON_1 ;
const Pin pinPB2 = PIN_PUSHBUTTON_2 ;
/** LED0 blinking control. */
volatile bool bLed0Active = true ;
/** LED1 blinking control. */
volatile bool bLed1Active = true ;
/** Global timestamp in milliseconds since start of application */
volatile uint32_t dwTimeStamp = 0;
* Local functions
* \brief Process Buttons Events
* Change active states of LEDs when corresponding button events happened.
static void ProcessButtonEvt( uint8_t ucButton )
if ( ucButton == 0 )
bLed0Active = !bLed0Active ;
if ( !bLed0Active )
LED_Clear( 0 );
else
bLed1Active = !bLed1Active ;
/* Enable LED#2 and TC if they were disabled */
if ( bLed1Active )
LED_Set( 1 );
TC_Start( TC0, 0 );
/* Disable LED#2 and TC if they were enabled */
else
LED_Clear( 1 );
TC_Stop( TC0, 0 );
* \brief Handler for Sytem Tick interrupt.
* Process System Tick Event
* Increments the timestamp counter.
void SysTick_Handler( void )
dwTimeStamp ++;
* \brief Handler for Button 1 rising edge interrupt.
* Handle process led1 status change.
static void _Button1_Handler( const Pin* pPin )
if ( pPin == &pinPB1 )
ProcessButtonEvt( 0 ) ;
* \brief Handler for Button 2 falling edge interrupt.
* Handle process led2 status change.
static void _Button2_Handler( const Pin* pPin )
if ( pPin == &pinPB2 )
ProcessButtonEvt( 1 ) ;
* \brief Configure the Pushbuttons
* Configure the PIO as inputs and generate corresponding interrupt when
* pressed or released.
static void _ConfigureButtons( void )
/* Configure pios as inputs. */
PIO_Configure( &pinPB1, 1 ) ;
PIO_Configure( &pinPB2, 1 ) ;
/* Adjust pio debounce filter patameters, uses 10 Hz filter. */
PIO_SetDebounceFilter( &pinPB1, 10 ) ;
PIO_SetDebounceFilter( &pinPB2, 10 ) ;
/* Initialize pios interrupt handlers, see PIO definition in board.h. */
PIO_ConfigureIt( &pinPB1, _Button1_Handler ) ; /* Interrupt on falling edge */
PIO_ConfigureIt( &pinPB2, _Button2_Handler ) ; /* Interrupt on falling edge */
/* Enable PIO controller IRQs. */
NVIC_EnableIRQ( (IRQn_Type)pinPB1.id ) ;
NVIC_EnableIRQ( (IRQn_Type)pinPB2.id ) ;
/* Enable PIO line interrupts. */
PIO_EnableIt( &pinPB1 ) ;
PIO_EnableIt( &pinPB2 ) ;
* \brief Configure LEDs
* Configures LEDs \#1 and \#2 (cleared by default).
static void _ConfigureLeds( void )
LED_Configure( 0 ) ;
LED_Configure( 1 ) ;
* Interrupt handler for TC0 interrupt. Toggles the state of LED\#2.
void TC0_IrqHandler(void)
volatile uint32_t dummy;
/* Clear status bit to acknowledge interrupt */
dummy = TC0->TC_CHANNEL[ 0 ].TC_SR;
/** Toggle LED state. */
LED_Toggle( 1 );
printf( "2 " );
* Configure Timer Counter 0 to generate an interrupt every 250ms.
static void _ConfigureTc(void)
uint32_t div;
uint32_t tcclks;
/** Enable peripheral clock. */
PMC->PMC_PCER0 = 1 << ID_TC0;
/** Configure TC for a 4Hz frequency and trigger on RC compare. */
TC_FindMckDivisor( 4, BOARD_MCK, &div, &tcclks, BOARD_MCK );
TC_Configure( TC0, 0, tcclks | TC_CMR_CPCTRG );
TC0->TC_CHANNEL[ 0 ].TC_RC = ( BOARD_MCK / div ) / 4;
/* Configure and enable interrupt on RC compare */
NVIC_EnableIRQ( (IRQn_Type)ID_TC0 );
TC0->TC_CHANNEL[ 0 ].TC_IER = TC_IER_CPCS;
/** Start the counter if LED1 is enabled. */
if ( bLed1Active ) {
TC_Start( TC0, 0 );
* Waits for the given number of milliseconds (using the dwTimeStamp generated
* by the SAM3's microcontrollers's system tick).
* \param delay Delay to wait for, in milliseconds.
static void _Wait(unsigned long delay)
volatile uint32_t start = dwTimeStamp;
uint32_t elapsed;
do {
elapsed = dwTimeStamp;
elapsed -= start;
while (elapsed < delay);
* Exported functions
* \brief getting-started Application entry point.
* \return Unused (ANSI-C compatibility).
extern int main( void )
#if defined ( __CC_ARM ) /* Keil µVision 4 */
/* Disable semihosting */
# pragma import(__use_no_semihosting_swi)
#endif
/* Disable watchdog */
WDT_Disable( WDT ) ;
/* Output example information */
printf( "-- Getting Started Example %s --\n\r", SOFTPACK_VERSION ) ;
printf( "-- %s\n\r", BOARD_NAME ) ;
printf( "-- Compiled: %s %s --\n\r", __DATE__, __TIME__ ) ;
/* Configure systick for 1 ms. */
printf( "Configure system tick to get 1ms tick period.\n\r" ) ;
if ( SysTick_Config( BOARD_MCK / 1000 ) )
printf("-F- Systick configuration error\n\r" ) ;
/* PIO configuration for LEDs and Buttons. */
PIO_InitializeInterrupts( IRQ_PRIOR_PIO ) ;
printf( "Configure TC.\n\r" );
_ConfigureTc() ;
printf( "Configure LED PIOs.\n\r" ) ;
_ConfigureLeds() ;
printf( "Configure buttons with debouncing.\n\r" ) ;
_ConfigureButtons() ;
printf( "Press USRBP1 to Start/Stop the blue LED D2 blinking.\n\r" ) ;
printf( "Press USRBP2 to Start/Stop the green LED D3 blinking.\n\r" ) ;
while ( 1 )
/* Wait for LED to be active */
while( !bLed0Active );
/* Toggle LED state if active */
if ( bLed0Active )
LED_Toggle( 0 );
printf( "1 " );
/* Wait for 500ms */
_Wait(500);
I've make some 8 bits projects with AVR but I'm newbie with ARM, please can someone help me please.
