Are there any tutorial for EPLAN?
seyyah
Advanced Member level 2
eplan tutorial
I decided to try this software for electrical drawings and documentation. It looked different to me than ordinary programs. Are there any tutorial for this program which will help me to start to use.
eplan p8 tutorial
EPLAN has different logic then other programs.
Last year I was on training to learn how to use Eplan and all his advanages. It's very powerfull software, but many things are not at logic places...
So, if you have some questions I can answer you.
Regards,
Mr.Cube
Reactions: taglub
    taglub
eplan tutorials
Actually i had no much time so i went on autocadE. Actually i didn't like autocadE either but it was easy to start to do something. May be i change it when i need again. I don't need much nowadays.
eplan user guide
Hi!
...And I've also got a 1700 page user guide if desired and possibly a large tutorial, which I'll have to split into two as its over 27MB!!!
Please let me know if anyone would like these posted - I'd recommend a colour laser printer for these as they're huge weighty tomes needing at least three reams of inkjet-paper and four sets of cartridges......!!!
Chris Williams
e-plan tutorial
I do not know if i am allowed to post a link to document p8_beginnersguide
which is :
if it is not allowed , pls remove directly
viid.de/ Eplan2.pdf
...and use google wise to find some things :wink:
:shock:
I've been on EPLAN P8 for 3 years, it is a very powerfull program and quite easy to use when you catch it, at first is a bit complicated, things aren't as obvious as they should be so the learning curve is a bit slow at first but you will like it when you are a bit more experienced with it. I really like the way things can be drawn and the use of macros, also his internal database for components.
I found many tutorial in the net, just use google, is very easy to found these. Even there is an official application from the manufacturer, something like a compendium or a tutorial inside a program, about 1CD size. I found it also in google.
This thread is full of pointless "email me the tutorial" posts which I have deleted. There is already some advice on how to find tutorial (Google it!) as well as a link the the pdf everyone seems to want mailing to them - **broken link removed**
Thread closed.
Keith
