[AVR] Arduino with digipot AD5293
Rajiv Tyagi
Digipot AD5293 is giving me a lot of trouble. Below is my code. I don't know why I can't get this to work or what I'm doing wrong. Can someone help, please?
[syntax=cpp]
#include <SPI.h>
void setup(){
  pinMode(10, OUTPUT); //CS
  pinMode(11, OUTPUT); //MOSI
  pinMode(12, INPUT);  //MISO
  pinMode(13, OUTPUT); //SCK
  Serial.begin(115200);
  writeCommand;
void loop(){
  unsigned int val;
  for (val = 0; val <= 1023; val++) {
    writeDigipots(val);
    //delay(10);
  for (val = 1023; val > 0; val--) {
    writeDigipots(val);
    //delay(10);
void writeDigipots(unsigned int val){
  SPI.beginTransaction(SPISettings(SPI_CLOCK_DIV8, MSBFIRST, SPI_MODE1));
  digitalWrite(10, LOW);
  //SPI.transfer(0x18); //send command byte
  //SPI.transfer(0x03);
  byte highbyte = val >> 8 + 0x04; //high wiper byte + command
  byte lowbyte = val & 0xFF;
  SPI.transfer(highbyte); //send wiper data high byte
  SPI.transfer(lowbyte); //send wiper data low byte
  digitalWrite(10, HIGH);
  SPI.endTransaction();
void writeCommand() {
  SPI.transfer(0x18); //send command high byte
  SPI.transfer(0x03); //send command low byte
[/syntax]
On the oscilloscope I can see the MOSI changing values, SCK is present and stable, CS is correct. What am I doing wrong?
Rajiv
Looks like you did not include the header file for the microcontroller which is running the SPI protocol.Include the microcontroller header file also.Then,the system might work.
Also,are the functions digitalWrite,SPI.transfer,SPI.beginTransaction a part of <SPI.h>?
If not,then they will not work,if you haven't defined them anywhere in the program.
Yes, those are all SPI methods from the SPI Library built into the Arduino IDE. I am getting no compiler errors - everything compiles without any warning or error messages.
Could you please check if I am sending the data correctly? Starting with the 0x1803 control code and the masking of the two bytes I send in the writeDigipots() function? The Analog Devices datasheet is so sketchy, I wonder how people get their digipots working? Their help is almost non-existent - the designated helper on the AD line knows almost nothing about the device and just advises to compare waveforms with the datasheet... :(
