[ARM] Arduino due Sam3X8E With Atmel Studio 6.1(SamICE Debugger)
pravin35
Newbie level 5
Pune/Coimbatore
hi guys,
i am using Arduino Due with Atmel Studio .
SAM3X8E ARM cortex m3 Processor.
Atmel Studio 6.1IDE.
SAMICE Debugger.
i am trying to read Analog Signal in the internal ADC & trigger of ADC is External Which i have given 1mhz.
i am trying to read 128 Samples in for loop .but i am getting only 2 or 3 Sample Which iam printing in Serial Port.
Kindly see the code i have attached in notepad file..
below is the While loop.....
while (1) {
start_adc();
/* Check if ADC sample is done. */
for (i =0 ;i<127;i++)
if (g_adc_sample_data.us_done == ADC_DONE_MASK) {
for (i = 0; i < NUM_CHANNELS; i++) {
printf("CH%02d: %04d mv. ",
(int)g_adc_sample_data.uc_ch_num[i],
(int)(g_adc_sample_data.
us_value[i] ));
puts("\r");
g_adc_sample_data.us_done = 0;
  • Adc_Seq_15channel.zip
i try to make you clear what i am trying for !!
i have CCD sensor Which has a output pattern (Refer pic1).The output of ccd is analog and the rate of 1msps.
I am connected the analog output to the SAM3X8E (Arduino Due). Adc configured as Ext trigger (Rising Edge) given 1mhz clock(same camera clock which ccd Triggered). Start and stop connected to port pin edge trigger . whenever 1 interrupt (start adc, Read ccd data) stop when 2 interrupt.(Refer : SI the clock mentioned in pic1).
Between start and stop there are 128 clocks (ccd will out 120 pixel analog output).. i need to read this 128 pixel in adc and load the data to 1d Array... please help how to make this logic ..
The above code is the example code . i will upload the real code that made for the mentioned logic..
expected is 128 data in buffer .
please let me know some more details required.
