Arduino delimiter, stores 12,24 data to (val = 12, val1 = 24)
eebhoi01
Full Member level 1
Hello guys,
My Arduino will be receiving a string data that has two values separated by a comma. Can anyone please help me split those values and assign it to two separate variables?
Say for example: the string is equal to 12,24. I wanted to make it val=12, val=24.
Thanks in advance
Best regards
if you look here
https://arduino.cc/en/Reference/String
you will see that strings is arrays of chars. So just look for the symbol "," and then split the results. The algorithm should be
if "," found copy the value into another string and then use atoi function
test="Hello,word";
char temp[5];
int i,j,val1,val2;
for (i=0;i<=test.length;i++){ //check entire string
if test[i]="," {//if comma found
for (j=0;j=i-1;j++)//for the beginning to the current position - 1 for the comma symbol
temp=test[j];//transfer the chars to temp string
val1=atoi(temp);
for(j=i+1;j=string.length;j++)//the remaining after comma symbol
temp[j]=test[j];//transfer the remain chars
val2=atoi(temp);
hope that helps.
if you look here
test="Hello,word";
char temp[5];
int i,j,val1,val2;
if test="," {//if comma found
val1=atoi(temp);
val2=atoi(temp);
hope that helps.
thank you for your reply sir,
but i cant get the code running,
i have questions, what type of variable is the test?
I will be getting data through Serial.read()
will it work if i set test = Serial.read(); ?
thank you
test is the string (char test[100]; or whatever length you need) which contains your data. Of course you should use test=serial.read();
To use the atoi function you need to use #include <stdlib.h>
I do not know what else your problem could be.
Hello Sir, this is my code based on your example:
#include <stdlib.h>
char test[5];
char temp[5];
int i,j,val1,val2;
void setup()
Serial.begin(9600);
void loop()
if (Serial.available())
val1=atoi(temp);
val2=atoi(temp);
error says: incompatible types in assignment of 'int' to 'char [5]'
im confusd, thanks in advance
test = Serial.read(); is not correct. It assigns only one byte to test. test should be something like test[100] and every time a data comes serially it should be assigned to test[] like
Code C - [expand]
8
i = 0;
while(i<100) {
if(serial.available()) {
   test[i] = serial.availabel();
   i++;
