Archimedean Spiral antenna....unbalanced....Vswr problem
kuhnny
Newbie level 6
Newbie level 6
I'm finding difficulty in designing unbalanced Archimedean Spiral antenna in HFSS....I designed for 1 - 10 Ghz...
but it is working at one frequency 1Ghz( i.e. poor return loss at other frequencies)
Behaving like narrow band antenna.
I excited with lumped port between two arms.
What will be the problem ?
What impedance did you use for your lumped port? A complementary Archimedean Spiral should exhibit an input impedance of 188 ohms.
I used 188.5 ohms. and im getting BW of 700MHz only. but it should be around 8-10 GHz.
What do you mean by unbalanced? Are you using an unbalanced feed, or is there some aspect of the design that causes this to be a non-complementary antenna design? Can you post a picture of the layout?
yah. It was unbalanced feed only. Substrate is kept hidden in the image.
