it that true???spikeyang said:For the same frequency bandwidth, CDMA can contain more users than GSM.
leoren_tm said:it that true???spikeyang said:For the same frequency bandwidth, CDMA can contain more users than GSM.
i read something that says, cdma would lesser its trasmission quility to occupy the calls....:?::?::?:
leoren_tm said:yha...but it didnt answer my question thou....
CDMA has a good quality, but this would be a tradeoff for a capacity.....
this means if CDMA would have a greater subscriber, it would lesser its quality....
need a explanation on it....
ty
tronix said:CDMA vs GSM
Let say we have four couples and they all have to propose to each other and also that proposal can be made inside a particular room only.
What GSM will do:
Let first couple go in - give them a moment or two - take them out and let the next couple go in - allow them some time and so on in a circular fashion till the task is complete.
What CDMA will do:
Let all the 4 couples go in at the same time and let all of them propose simultaneously but now each will be having a decoder which will decode only one of the proposals that is meant for him/her.So its like one will get all the signals but will be able to decode only what is meant for him.
Regards
tronix
what is frequency reuse??konarkk said:No need of freq reuse , secure mean of transmission
FSio said:Apparently CDMA is better than GSM for Power/BW.
So, Why most companies (operators) prefer buy GSM equipments instead of CDMA?
