application of Agilent E5071C network analyzer
zmkm1402022
Newbie level 1
Newbie level 1
Hi everyone,
I am trying to use E5071C network analyzer to measure the impedance of an device over a frequency band from 1kHz to 2MHz. I have little experience in using ENA, and my understanding of E5071C is limited in measuring the S parameters.
What should I do if I want to measure the voltage ratio between port 1 and port 2? how should I setup the ENA to achieve this. Or, is that possible to convert the S parameter to the result of voltage ratio as mention above?
