anyone using PICAXE microcontroller???
verilog_coder
Member level 3
Member level 3
Pakistan
Anybody using picaxe microcontrollers? I need assembly code for following programme
main:
tune 0, 6, ($AA, $85, $43, $42, $40, $8A, $C5, $43, $42, $40, $8A, $C5,
$43, $42, $43, $C0, $65, $65, $65, $EA, $C5, $43, $42, $40, $8A, $C5,
$43, $42, $43, $80)
goto main
Please also have a look at this topic
Thanks in advance
Re: anyone using picaxe microcontroller???
I am aware of the fact that PICAXE is a "normal" PIC just with added BASIC interpreter ..
And that "just" becomes the main "headache" ..
I think you will have to accept that fact and rather try to purchase one (or more) pieces of PICAXE-08M on-line from, for example: **broken link removed**
Also, I don't think anyone will be able to help you with assembly code(s) which will be excuted by a "normal" PIC in the same way as the TUNE command is executed by PICAXE-08M ..
Regards,
IanP
well i dont want to buy them. If i can see some assembly code of this instruction then i will try to write assembly code for simple pic. Beside these controlleres does not have much programme memory. Only 80 lines.
