anyone got 8051 programmer or development board circuit?
yewkhip
Newbie level 2
development board circuits
Anyone got these circuit? I'm intend to build a simple one for self learning. i'm new in embedded sys and just got some experience in pic.
Bye
Re: anyone got 8051 programmer or development board circuit
If you like chinese,www.21ic.com in forum have much so projects.
I would recommend to use Atmel 89c51RD2 or ED2. They can be programmed with simple wire connection (with MAX232 logic levels conversion IC) to RS232. Free software (Flip) is available on Atmel site. Also, with these uC you can use FlashMon from Keil for easy hardware debug.
Ace-X.
hi'
try using easy downloader freely available on net
try this one @ **broken link removed**
Try to use AT89S51 or S52 from At**mel, they are In-System Programmable, having 4/8K of program memory.
You should go to the following site to get the board & software for programming 8051:
Good luck to you
So I need your idea to Pre-Project about 8051.
Anyone Could guide me about this.
8051 is easy to work. You need a HW Programmer and you can develop your project more quickly. The HW Programmer is quite cheap and more convinent.
hi
i started with 8051 and i suggest the same.
u can easily get AT89s8252 of 8051 family for which compiler is free on web
(keil) and the programmer is so simple as it can be assembled in a bread board
here it is
all the best
