hangjien
I am going to build a 27MHz transceiver. I was required to design a low cost transceiver using FSK at 27MHz. This transceiver will need to be low cost, small and robust, with an indoor operating range of about 30m. This transceiver will incorporate for transmission an FSK modulator, low power transmitter and near isotropic antenna radiation characteristics. For reception this tranceiver will require a low noise amplifier and FSK demodulator.
I can't find an ICs operating in this frequency in the market. So now i am going to build the transceiver myself. As i am going to build the power amplifier first, what should i do with it.
