If the company you are applying is an IP provider, then IP integration could be one task and check for the DRC/LVS. Usually, IP providers give the footprint to the designers and after the layout is completed, the footprint is removed and the original IP is integrated to the design. After this the verification checks are done and tapedout to fab.
I think it will be a SOC project.
You'll be work on top level module communating with architecture engineers and IP designers.
May be Synthesis scripts or DFT scripts or some other work .
The Integration group is very necessary for A matured company to design a complex chip.
An IC Integration Engineer is a wafer fab engineer whose resposibility is in making the individual unit procersses that make up the manufacture of an IC, work together to give the correct IC performance and reliability. To become an Integration Engineer, you would need to have experience as a Fab process Engineer, be very proficient in Device Physics and know a little about IC layout and some design. Typically, Integration Engineers are 7 year+ experience in wafer fabs.
