anybody can check my program
sonic05
Member level 1
Manila
please help me...
#include <16F877A.h>
#fuses XT,NOWDT,PUT,NOBROWNOUT,NOLVP
#use delay(clock = 4000000)
#byte PORTA=0X05
#byte PORTC=0x07
#byte PORTB=0X06
#define A0 PIN_A0
#define A1 PIN_A1
#define A2 PIN_A2
#define A3 PIN_A3
#define A4 PIN_A4
#define A5 PIN_A5
#define E1 PIN_E1
int sec1,sec2,min1,min2,hour1,hour2;
int secs1,secs2,mins1,mins2,hours1,hours2;
int num1=5,num2=5,num3=5;
int counter=125;
int flag=0;
const int table[10]={0b00111111,
0b00000110,
0b01011011,
0b01001111,
0b01100110,
0b01101101,
0b01111101,
0b00000111,
0b01111111,
0b01101111};
void main()
PORTB=0X00;
PORTC=0X00;
set_tris_a(0xff);
set_tris_c(0x00);
set_tris_b(0x00);
set_RTCC(6);
setup_counters(RTCC_INTERNAL,RTCC_DIV_32);
enable_interrupts (INT_RTCC);
enable_interrupts (GLOBAL);
for(;
PORTB=table[sec1];
PORTC=0X01;
delay_ms(15);
PORTB=table[sec2];
PORTC=0x02;
delay_ms(15);
PORTB=table[min1];
PORTC=0x04;
delay_ms(15);
PORTB=table[min2];
PORTC=0x08;
delay_ms(15);
PORTB=table[hour1];
PORTC=0x10;
delay_ms(15);
PORTB=table[hour2];
PORTC=0x20;
delay_ms(15);
if(flag==1){
flag=0;
if(input(A4)==1)
disable_interrupts(INT_RTCC);
if(input(A2)==1) { --num1; }
if(num1==0){
if(++min1>9) {
min1=0;
if(++min2>5) { min2=0; }
num1=5;
if(input(A3)==1){ --num2; }
if(num2==0)
if( ++hour1>9 )
hour1=0;
++hour2;
if( (hour2==1) & (hour1==3) ) {
hour1=1;
hour2=0;
num2=5;
if(input(A1)==1) { --num3; }
if(num3==0){
if(++sec1>9) {
sec1=0;
if(++sec2>5) { sec2=0; }
num3=5;
else if(input(A4)==0){
enable_interrupts(INT_RTCC);
///////////////////////////////////////////////////////////im not sure in this part
if(input(E1)==1)
if(num1==0){
if(++mins1>9) {
mins1=0;
if(++mins2>5) { mins2=0; }
num1=5;
if(num2==0)
if( ++hours1>9 )
hours1=0;
++hours2;
if( (hours2==2) & (hours1==4) ) {
hours1=1;
hours2=0;
num2=5;
if(num3==0){
if(++secs1>9) {
secs1=0;
if(++secs2>5) { secs2=0; }
num3=5;
else if(input(E1)==0){
#int_RTCC
microII()
{ //void switch_time();
if(input(A5)==0)
if(--counter>0)return;
counter=125;
flag=1;
if(++sec1>9){
sec1=0;
if(++sec2>5){
sec2=0;
if(++min1>9){
min1=0;
if(++min2>5){
min2=0;
if( ++hour1>9 )
hour1=0;
++hour2;
sec1=0;
sec2=0;
min1=0;
min2=0;
hour1=1;
hour2=0;
///////////////////////////////////////////////////////////and also here...
else if
(input(A5)==1)
counter=125;
flag=1;
if(++secs1>9){
sec1=0;
if(++secs2>5){
sec2=0;
if(++mins1>9){
min1=0;
if(++mins2>5){
min2=0;
if( ++hours1>9 )
hours1=0;
++hours2;
secs1=0;
secs2=0;
mins1=0;
mins2=0;
hours1=0;
in this program...if i press PIN_A5 the program of 24 hours will run but if not the program of 12 hours will run..but it still not working but when i remove all the part that im not sure the program of 12hours clock will run..
and can you please help me also to make a program for stopwatch and assign a designated switch..?
Do you have the pin configuration of your h/w i mean if you are using 7 segment how it is connected to portb.
i used led but it is like a 7segment common cathode...all positive connected to PORT B while all negative connected to PORT C...do you have a yahoo messenger?
---------- Post added at 14:33 ---------- Previous post was at 14:31 ----------
a(0x01)
b(0x02)
c(0x04)
d(0x08)
e(0x10)
f(0x20)
g(0x40)
No I dont have yahoo messenger. I will make the code but first i need to study it properly.
I have not simulated the program but the scan of LEDs takes 6 x 15mS (=90mS) to complete which is far too slow. The display will flicker badly. Try changing the 15mS delays to 2mS or even 1mS.
Brian.
what is the use of Port A.
port A are connected to 4switch
---------- Post added at 15:30 ---------- Previous post was at 15:28 ----------
you can also see my scheamatic in this site,..the 1st schematic is my circuit that i make but i change something because i used common cathode,...you can see in second schematic how the transistor connected in 7segment common cathode
That means Port a is for adjusting sec , min , hour, & mode.
#byte PORTA=0X05
#byte PORTC=0x07
#byte PORTB=0X06
#define A0 PIN_A0
#define A1 PIN_A1
#define A3 PIN_A3
#define A4 PIN_A4
int counter=125;
int flag=0;
----------------------------------look up----------
0b00000110,
0b01011011,
0b01001111,
0b01100110,
0b01101101,
0b01111101,
0b00000111,
0b01111111,
0b01101111};
void main()
-------------------o/p---
PORTB=0X00;
PORTC=0X00;
-------------------i/p---
PORTA=0XFF;
set_tris_a(0xff);
set_tris_c(0x00);
set_tris_b(0x00);
---------------register init---------
set_RTCC(6);
------------ift lp--------------
for(;
----===Skip 1st time----
---- accessing look up table-----------
PORTB=table[sec1];
PORTC=0X01;
delay_ms(8);
PORTB=table[sec2];
PORTC=0x02;
delay_ms(8);
PORTB=table[min1];
PORTC=0x04;
delay_ms(8);
PORTB=table[min2];
PORTC=0x08;
delay_ms(8);
PORTB=table[hour1];
PORTC=0x10;
delay_ms(8);
PORTB=table[hour2];
PORTC=0x20;
delay_ms(8);
-------------------------------------12 hr
--------------skip & go to [1] for general configuration (reset)----------------
if(flag==1){
flag=0;
---------------------a0: min, a1: hr, a3: sec, a4: mode
if(input(A4)==1)
if(input(A0)==1) { --num1; }
if(num1==0){
if(++min1>9) {
min1=0;
if(++min2>5) { min2=0; }-----max min:59
num1=5;
}-----------min f--------------
if(input(A1)==1){ --num2; }
if(num2==0)
if( ++hour1>9 )
hour1=0;
++hour2;
hour1=1;
hour2=0;
}------------------max hr: 12
num2=5;
}-------------------------------hr f
if(input(A3)==1) { --num3; }
if(num3==0){
if(++sec1>9) {
sec1=0;
}-------------------------max sec 59---
num3=5;
}---------- sec f
---------------0x004------------
-------------------------------------24 hr
if(input(A4)==1)
if(num1==0){
if(++mins1>9) {
mins1=0;
num1=5;-----------------------max min:59
------min f
if(num2==0)
if( ++hours1>9 )
hours1=0;
++hours2;
hours1=1;
hours2=0;
num2=5;------------------------max hr: 24
------hr f
if(input(A2)==1) { --num3; }
if(num3==0){
if(++secs1>9) {
secs1=0;
num3=5;--------------------------max sec: 59
------------sec f---
------------------------------------------[1]--
----------------------------------0x004
#int_RTCC
microII()
--------------------- for 12 hr
if(input(A4)==0)
counter=125;
flag=1;
if(++sec1>9){
sec1=0;
if(++sec2>5){
sec2=0;
if(++min1>9){
min1=0;
if(++min2>5){
min2=0;
if( ++hour1>9 )
hour1=0;
++hour2;
sec1=0;
sec2=0;
min1=0;
min2=0;
hour1=1;
hour2=0;
--------------------- for 24 hr
else if
(input(A4)==1)
counter=125;
flag=1;
if(++secs1>9){
sec1=0;
if(++secs2>5){
sec2=0;
if(++mins1>9){
min1=0;
if(++mins2>5){
min2=0;
if( ++hours1>9 )
hours1=0;
++hours2;
secs1=0;
secs2=0;
mins1=0;
mins2=0;
hours1=0;
yes...but i dont know if it will run...
im not sure for those part of 24hrs but when i used only the 12hours programs it will run...but for 24 hours nothing happen...can you please help me..
to build a program...for that...or i have some option here
1st....12hrsclock with stopwatch
or 12hrs clock that can become a 24hrs...what do you think?
I have made small modification in i/p configuration as a0: min, a1: hr, a3: sec, a4: mode.
Now just change the h/w confg compile and simulate the code I hope it will run if it is giving still problem then betwn function of 12 & 24 hr use some nop.
but can you please help me for some part of a program?
