any source code for this circuit
omar2002
Newbie level 3
Newbie level 3
Ireland
Hello all
I made this circuit but i can't build the source code for it
I tried several times, but it does not work.
Assume your build gives some kind of error message ?
Can you post the original source code or show the link to it .
thanks for reply .
  • 6ch-.rar
?? - just read the code into MPlab and it builds error free - what problems do you get ?
As you can see there is no problem
Try to add a pull up resistor at the output of IR receiver if you are getting some improper result.
sorry it's doesn't work
I dont know the ASM and all. So i did not go through your code. But for testing purpose, you can use an IR led with a carrier frequency of 38Khz and check whether your circuit behaves as proximity sensor.
