i have found that there is some prob in the size of waveport & improve my design, also it reaches towards the desired, but not the exact result.....still there is sth missing in my design....may anyone plz find....
I can do the parametric analysis. When you make a geometric feature, input some dimension as a variable, which makes it a local (design, not project) variable, then prompts you to enter a value. They you can add a parametric analysis with that value, sweeping it or whatever.
