My friend is building an energy monitoring for single phase AC. I only helped him in soldering but I do have some knowledge in electronics and arduino. I have soldered already 10 boards (assuming it has been tested already which I later found out was not). For this case, we will be using Tiva. I can follow his algorithm and PCB circuit but I didn't have actual experience using Tiva.
I can trace what I have soldered and this is what I assumed to be the voltage transformer part of the wattmeter. This is just a transformer to step down the voltage and some signal conditioning circuit to so that we will be in range of Tiva input by offsetting the negative half cycle to Tiva's 0 voltage.
When it was finished, it has to be tested. When it was tested, output waveform Tiva has fetched looked something like this:
The red part is interesting because I don't have an idea what could have caused it. It is a sine wave with a clipped square wave like shape on the positive half cycle. I don't have the exact fetched values since he was the only one showing to us the output and I don't want him to feel bad if ever something was wrongly done (either from design or soldering part).
The processor has a power supply of 3.3V and probably 0 - 3.3V analog input range. Offsetting the AC input to 3.3V can't but result in clipping of positive halfwaves. Retry with 1.65V offset.
Ooops. I forgot to add the other resistor of the voltage divider there in the to have 1.65 volts in the capacitor.
This was the designed and implemented PCB.
This schematic had the clipped output which I can't imagine where we were wrong. Something wrong with pin placement in Tiva? Something short-circuited? Non-linear voltage transformer response? I can't imagine where to troubleshoot.
a small 9V transformer may easily output 1.5 x 9V whith low load. (the 9V are for full load)
9V x 1.5 = 13.5V
this gives 13.5V x 1.414 = 19.1Vp
or 38.2Vpp
divided by 11 (your divider) it still is 3.47V, which is more than 3.3V.
Use a voltmeter to check true transformer output voltage.
