You mean, it doesn't do it automatically. It's quite easy to get it calculated in LTspice or other SPICE variants, e.g. using .fourier analysis.Unfortunately, LTspice doesn't do power factor.
The 1MB(!!!) PDF you attached contains this image:The attached mains voltage and current...
You're kidding, right? The green trace doesn't even cross zero - it's positive all the way.I dont see the dc.
