activex
Newbie level 3
- Joined
- Jul 4, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 30
Hello
I am responsible for a project that involve in antennas transmission and receiving. I have two loop-antennas and I want to set them up so that they can communicate to each other, as show in the figure. I will call one as a master antenna and one is a slave antenna. The master is the one I will keep at my computer and the slave is the one I will randomly place around the room. I want to master to transmit a status-request signal to the slave and I want the slave to response with a pulse. I am using Arduino board as a micro-controller to send and receive these status-request and response, respectively. In term of the microcontroller side I am very comfortable in recieveing and transmitting status request. What I need help with is how to I initiate that request and how to initiate that response to make the antennas transmit/receive.
The frequency I am working at is LF of which around 500 Hz to 5 Kz and the expected power is 1 KW.
My idea is as follow but I am unsure whether its valid or not.
I will use a H-bridge to deliver the power to the antennas and also I am using the microcontroller to control that H-bridge.
Does that make sense?
Any input is greatly appreciated.
Thanks
L.M
Thanks
L.M
