Oct 28, 2004 #1 C coniglioe Member level 1 Joined Apr 2, 2002 Messages 40 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 211 use of ansoft designer hi I simulated a microstrip antenna with ansoft designer v1 and v2. the simulation time and the memory used are doubler with designer v2. Why? regards
Nov 16, 2004 #2 J jgiardini@invap.com.ar Newbie level 5 Joined Jul 5, 2004 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 116 Re: use of ansoft designer I haven't used v2. However, this may help: In v1 the solver that is used affects the solving time and memory. The solver selection settings are the same in both cases? In v1 you can configure this.
Nov 16, 2004 #3 W Wiley Member level 4 Joined May 17, 2004 Messages 68 Helped 10 Reputation 20 Reaction score 5 Trophy points 1,288 Activity points 779 Re: use of ansoft designer Also check the mesh. Are the number of unknowns the same?
Nov 18, 2004 #4 G George137 Junior Member level 3 Joined Feb 29, 2004 Messages 28 Helped 3 Reputation 6 Reaction score 3 Trophy points 1,283 Activity points 200 Re: use of ansoft designer I don't think I am having the same problem. I guess it might be something in your design. Are you sure you have the same parameters?
Nov 18, 2004 #5 S si_green Junior Member level 2 Joined Nov 13, 2004 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 171 use of ansoft designer please upload your work!! let us see!!
Dec 28, 2004 #6 A anna_8184 Newbie level 4 Joined Nov 16, 2004 Messages 7 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 46 use of ansoft designer It can not be possible.I guess it might be something in your design.
Jan 12, 2005 #7 H hitmo Member level 1 Joined Jan 4, 2005 Messages 37 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Activity points 287 Re: use of ansoft designer check ur design for any discontunity as it mught increase the mesh size n slow down the simulation
