obrien135
Full Member level 5
- Joined
- Nov 10, 2009
- Messages
- 240
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Connecticut
- Activity points
- 3,259
I built an op amp circuit with an LM675 op amp. The supply was supposed to be 17 volts from plus rail to minus rail. But it ended up being about 16.5 VDC. The circuit common or "ground" midway between the rails (it's a single supply circuit) was implemented with a zener diode. The closest I could get to 8.5 volts was 8.7V and it ended up reading about 8.9 or 9.0 V. The op amp output seems to be stuck at around minus rail. Is this due to the offset caused by the uneven supplies, or simply not enough supply voltage? The minimum supply voltage for the LM675 is 16V. I am using a non-inverting configuration.
