ANDing 3 Conditions using && Operator MikroC PIC
asking
Full Member level 5
Full Member level 5
Hello,
i want to use following condition is it true ? i want to AND 3 conditions together..
if (PORTA.F1 == 1 && PIR1.TMR1IF == 1 && FLAG_1 == 1)
do something;
Thanks
Code C - [expand]
if ((PORTA.F1 == 1) && (PIR1.TMR1IF == 1) && (FLAG_1 == 1))
tHANKS
I need one more help from you dear
i am trying to increase count = count + 1; using above situation. Everytime above condition is true it should incremenet the value of count = count + 1; means count is incremented on every true of above condition.
i have used code but i am not successful
if ((PIR1.TMR1IF == 1) && (PORTA.F1 == 1) && (FLAG_1 == 1))
COUNT = COUNT + 1;
FLAG_1 = 0;
Please help :D
Presumed all variables are binary, you can simplify the expression
if (PORTA.F1 && PIR1.TMR1IF && FLAG_1)
Your code will increment the count every time the test is made while the port bits are high. I assume you want to only count once for each time the condition becomes true. So, you need to have a flag you set when the condition becomes true and cleared when the condition becomes false. Only count when you first detect the condition being true.
Keith
Keith
Keith you're right
I have implemented that i am successful in that case :) thanks for suggestion :)
