rnehrboss
Newbie level 5
I have this circuit that "AND's" a bunch of switches together to then NAND's that to a final Solenoid. The input switchs also power on and off solenoids as well as act as inputs to the MC14082 chips.
The problem is that the input switches cause some kind of bounce that cause the output solenoid to pulse up and down even though the other switches are not pulled low.
The final solenoid should remain energized unless all other solenoids are de-energized.
BTW I know I drew the IRL520 wrong, but it is wired right. Everything works, I just don't like the extra bounce on the output solenoid.
I tried a diode across the input solenoid, but that didn't do it.
Thanks in advance.
Thanks in advance.
