mmurali
Newbie level 3
Analysis of code
I got this code from a fellow designer.
process (CLK, RES_N)
begin
if RES_N = '0' then
COUNT <= "00000000";
SOP_INT <= '0';
EOP_INT <= '0';
elsif rising_edge(CLK) then
if ENABLE = '1' then
COUNT <= COUNT + 1;
if SYNC_SIG = '1' then
SOP_INT <= '0';
EOP_INT <= '0';
elsif START_SIG = '1' then
COUNT <= "00000001";
SOP_INT <= '1';
EOP_INT <= '0';
elsif COUNT >= "11111110" then
SOP_INT <= '0';
EOP_INT <= '1';
else
SOP_INT <= '0';
EOP_INT <= '0';
end if;
end if;
end if;
If you notice he's assigned COUNT outside of the lower if condition instead of doing it within the 'else' condition. Is this code ok? I'm a bit concerned as to how the synthesis tool will interpret this code. If start_sig = '1' then COUNT will have two logic paths. In VHDL does the if statement behave like a case statement where there is default statement on top.
Thanks.
begin
if RES_N = '0' then
SOP_INT <= '0';
EOP_INT <= '0';
COUNT <= COUNT + 1;
SOP_INT <= '0';
EOP_INT <= '0';
SOP_INT <= '1';
EOP_INT <= '0';
SOP_INT <= '0';
EOP_INT <= '1';
else
SOP_INT <= '0';
EOP_INT <= '0';
end if;
end if;
end if;
Thanks.
