Here is my full program.......
#include <REGX51.H>
#define TIMER0_COUNT 0xDC11
/* LCD command */
#define DISPLAY_ON 56
#define CURSOR_OFF 12
#define CURSOR_RIGHT 6
#define CLEAR 1
#define CURSOR_HOME 2
#define GOTO_LINE_2 192
#define GOTO_LINE_1 128
/* LCD control lines */
#define ENABLE 1
#define DISABLE 0
#define READ 1
#define WRITE 0
#define COMMAND 0
#define DATA 1
#define rs P3_5
#define rw P3_4
#define enable P3_3
#define adc_in P0
#define adc_rd P2_0
#define adc_wr P2_1
static unsigned timer0_tick;
const char int2char[]="0123456789";
void delay_2ms(void) {
unsigned char i,j;
for (i=0;i<3;i++)
for(j=0;j<255;j++)
void write_LCD_command(unsigned command)
rw=WRITE;
rs=COMMAND;
enable=ENABLE;
P1=command;
enable=DISABLE;
rs=1;
rw=1;
delay_2ms();
void write_LCD_data(unsigned LCDdata)
rw=WRITE;
rs=DATA;
enable=ENABLE;
P1=LCDdata;
enable=DISABLE;
rs=0;
rw=1;
delay_2ms();
void set_LCD(void)
write_LCD_command(DISPLAY_ON);
write_LCD_command(CURSOR_OFF);
write_LCD_command(CURSOR_RIGHT);
void clear_LCD()
write_LCD_command(CLEAR);
write_LCD_command(CURSOR_HOME);
display_LCD_string(char *p)
while(*p)
write_LCD_data(*p);
p++;
void gotoxy(unsigned x,unsigned y)
if(x==1)
write_LCD_command(GOTO_LINE_1+y);
else
write_LCD_command(GOTO_LINE_2+y);
void display_LCD_number(unsigned char number)
unsigned char x,y,i=2;
int z;
z=(int) number;
z=z<<1;
x=z;
y=x;
gotoxy(2,0);
write_LCD_data(int2char[y]);
gotoxy(2,1);
display_LCD_string(".");
x=z;
y=x;
gotoxy(2,2);
x=z;
y=x;
gotoxy(2,3);
gotoxy(2,4);
display_LCD_string("V");
static void timer0_isr(void) interrupt 1 using 1
TR0=0;
TL0=(TIMER0_COUNT & 0x00FF);
TH0=(TIMER0_COUNT >> 8);
TR0=1;
timer0_tick++;
if (timer0_tick==200) {
adc_wr=0;
timer0_tick=0;
adc_wr=1;
static void int0_isr(void) interrupt 0 using 0
unsigned char voltage;
adc_in=0xFF;
adc_rd=0;
voltage=adc_in;
voltage=voltage <<1;
adc_rd=1;
gotoxy(2,0);
display_LCD_number(voltage);
static void timer0_initialize(void)
EA=0;
timer0_tick=0;
TR0=0;
TMOD &= 0XF0;
TMOD |=0x01;
PT0=0;
ET0=1;
TR0=1;
EA=1;
void main (void) {
set_LCD();
clear_LCD();
display_LCD_string("Output Voltage =");
timer0_initialize();
IT0=1;
EX0=1;
while(1);
