Analog Logic ?
princeanalog
Newbie level 1
Nashville,TN
What if you use band-pass, band-stop, high-pass and low pass filters to create logic states and information filtration systems. ? The band-pass and band-stop would be the equivalent of neurotransmitter function like inhibitors for band-stop. The high-pass low pass could be used to create And ,Or, Nand, Nor etc functioning with transistors and wiring.
Yeah can do, but it ultimately reduces to another digital like system.
Sorry I have not replied sooner. My life has been one struggle after another. Any way the capacity of such a system to amplify voltages because of the ac signals overlapped with musically calculated audio tones can make for am and fm modulation of a carrier signal as well as power virtually any sized motor through bridge rectifiers for dc and rectifiers and oscillators for ac . One can also use old tape recorders or new digital ones for Rom which in conjunction with an old modified watch or alarm clock more likely the robot can be set to go off at specific times by recording audio signals ! Which though it might eventually get anoying could make for a simplified analog musical R2D2!
