analog differentiator with large time value
garimella
Full Member level 5
Can we have an idea to build an analog differentiator where dt is in minutes. Is it actually possible?. My process is very slow. Wanted to avoid processor in this regard.
FvM
Super Moderator
Staff member
Bochum, Germany
Surely possible, e.g. 10 µF*12 MOhm = 2 min.
You want to specify a bandwidth limit to avoid overload by amplifier noise and achieve stability easily.
KlausST
Super Moderator
Staff member
and don´t use a electrolytics because of it´s leakage current. And I don´t recommend to use ceramics becuase of their unlinearity.
Thus I´d use a foil capacitor, a good OPAMP, and a PCB layout maybe with guard ring to minimize (over years.. with humidity, dirt and whatever may come...) the leakage current..
It will work. But If I had to do it, I´d use a microcontroller.
In detail it depends on the precision, cost, effort...
Klaus
garimella
Full Member level 5
Initially I thought of using micros, but my customer wants a software validation report which makes it burdensome. Therefore planning for all hardware. Any proven reference design available? And FvM, you mean 20sec and not 2 Minutes?
garimella
Full Member level 5
Please help me to arrive at BW specifications. The input changes by around 10mV/min (max). Input waveform is more like a ramp. With these inputs only provided, let me know how to arrive at specs that you just mentioned in post #6
danadakk
Here is a gross sim of a long term differentiator. Uses the ap note to get
at the performance, and part values, you want. In addition use ap note
NI input R to minimize offsets, etc.. -
Regards, Dana.
garimella
Full Member level 5
Just curious, but If wish to implement a differentiator in FPGA (to avoid s/w), how do I realize RC dVin/dt in hardware?
FvM
Super Moderator
Staff member
Bochum, Germany
In time discrete signal processing (e.g. in FPGA), differentiation is replaced by discrete difference of adjacent samples.
dx/dt = (x(n+1) - x( n)/Tsamp
garimella
Full Member level 5
FVM, what is equivalent of RC in discrete domain, is it Tsamp=1/RC? How do I map 1minute to the sampling interval?
danadakk
These might help.
Regards, Dana.
garimella
Full Member level 5
I have just analyzed the discrete version of the differentiator. Strangely, it appears that if x[n] and x(n-1) are displaced by one minute, there is a likelihood of missing intermittent variations of the signal. Like a spike superimposed on a ramp for small duration. Analog version reflects the change. So I guess we may require many more intermittent samples and not just two as indicated in #10.
FvM
Super Moderator
Staff member
Bochum, Germany
In a sampled data system, the sampling rate should fulfill the Nyquist criterion. Respectively, if the sampling rate is 1/min, there should be no intermittent signal variations, or the sample rate has been selected inadequately.
A sampling rate decimation can take place in the data path if appropriate, but it would involve a decimation filter.
Seriously, I can't imagine that it's reasonable to use such a low sampling rate for your data, whatever the signal bandwidth is. As explained before, the sampling rate acts as a scaling factor in the differentiator, but you are free to implement a differentiator time constant of your choice independent of the sampling rate.
garimella
Full Member level 5
Hi FvM
Ok. In my case , if I take 1 second as a sampling time, then I will have 60 samples. So in effect the output will me x[60]-x[1], but the values should slide down , I mean present value should be copied the past variables and so on, like x[59]=x[60] .... x[2]=x[1] etc after one minute duration. Is this implementation correct?. In that case I am expecting spike duration for 2 second and 1 second sampling time should meet the Nyquist criteria.
FvM
Super Moderator
Staff member
Bochum, Germany
I would implement the differentiator with 1Hz samples and 60s time constant simply this way
dx/dt = 60*(x(n+1) - x( n))
No need to remember more than a previous value for a first order system.
garimella
Full Member level 5
So you mean that only adjacent samples would suffice but multiplied by scaling factor. Theoretically if I increase sampling rate say 10Hz would the scaling factor become 600?. Also it appears from #17 that there is no wait time for 60 seconds. it is almost instantaneous.
danadakk
This might be of interest in consideration of the order of the differentiator
and impact on response -
Regards, Dana.
garimella
Full Member level 5
Yes I checked it out on rick lyons article. However after some simulations, i discovered that in analog version equation for a differentiator, RC dvin/dt, the factor RC denotes the time duration when the slope needs to be estimated. High frequency will be let through as it is a high pass filter. But I am afraid that sampled differentiator system tends to block high frequency signals if the sampling intervals are large enough. This proves the point that historical samples are necessary for appropriate computation of a derivative. I was unable to get any similar responses with analog vs digital ones given the input stimulus.
LaTeX Commands Quick-Menu:
