sagar474
Full Member level 5
- Joined
- Oct 18, 2009
- Messages
- 285
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,318
- Location
- India,kakinada
- Activity points
- 3,122
Where the instruction so the program are stored
code segment?
data segment?
And how the 8086 differentiates the code and data?
code segment?
data segment?
BITS 16
start:
mov ax, 07C0h ; Set up 4K stack space after this bootloader
add ax, 288 ; (4096 + 512) / 16 bytes per paragraph
mov ss, ax
mov sp, 4096
mov ax, 07C0h ; Set data segment to where we're loaded
mov ds, ax
mov si, text_string ; Put string position into SI
call print_string ; Call our string-printing routine
jmp $ ; Jump here - infinite loop!
text_string db 'This is my cool new OS!', 0
print_string: ; Routine: output string in SI to screen
mov ah, 0Eh ; int 10h 'print char' function
.repeat:
lodsb ; Get character from string
cmp al, 0
je .done ; If char is zero, end of string
int 10h ; Otherwise, print it
jmp .repeat
.done:
ret
times 510-($-$$) db 0 ; Pad remainder of boot sector with 0s
dw 0xAA55 ; The standard PC boot signature
