Mohamed Slama
Member level 4
- Joined
- Nov 8, 2013
- Messages
- 72
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 443
Hi all
this code :
when i push button (high) that connected to Portb.F0
the counter will increment as follow ( 1 ,3 ,5,7,9, 11, 13, 15 )
and store these values into a vector of length 8
when Portb.f0 pushed down (low) ( the micro controller supposed to display this vector value by value each 400 ms ,But micro controller display these value correctly in the first time but in the second time it display 0 then 0 then ...... to eight zero
third time it display correctly and so on , what is the problem ??
this code :
// LCD module connections
sbit LCD_RS at RC6_bit;
sbit LCD_EN at RC7_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISC6_bit;
sbit LCD_EN_Direction at TRISC7_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
//variables
char Num_txt[7];
unsigned char i =0 ;
unsigned char x =0 ;
void _Init()
trisd.f0=0;
trisb=1;
lcd_init();
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Cmd(_LCD_CLEAR);
void main()
unsigned int s_vector[8];
_Init();
for(;;)
if(portb.f0==1) {
for (i=0;i<8;i++){
s_vector[i]=2*i+1 ;
LongWordToStr(s_vector[i],Num_txt);
lcd_out(2,1, Num_txt);
delay_ms(500);
if (i==9) i==0;
else {
for(x=0;x<8;x++){
LongWordToStr(s_vector[x],Num_txt);
lcd_out(3,1, Num_txt);
delay_ms(400);
x=0;
