[SOLVED] AMS simulation Model parameters
prcken
Advanced Member level 1
Shanghai
I am trying to use SpectreVerilog simulator for mixed-signal simulation.
I found a notes here
I had a problem at the step of "Change Default IE Library Name to "UCD_Analog_Parts," or what ever your analog library is called, and press ok."
After changing to the PDK library i used, the model parameters didn't show up, as below
did you have the problem before?
Thanks!
