[AVR] am having problems with using oshonsoft to write/read codes into EEPROM of AVR MCU
TOCHI
Newbie level 5
Newbie level 5
I am finding it very difficult to write basic programs in oshonsoft compiler for reading/writing four different numbers into the EEPROM of AVR (Atmega 16L) microcontrollers....
pls, i need urgent help. thank you.
The codes are added below ( basic program for oshonsoft compiler)...
Define SIMULATION_WAITMS_VALUE = 1
DDRA = 0 'setting porta as input
Define LCD_LINES = 2
Define LCD_CHARS = 16
Define LCD_BITS = 8
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTD
Define LCD_RSBIT = 1
Define LCD_EREG = PORTD
Define LCD_EBIT = 3
Define LCD_RWREG = PORTD
Define LCD_RWBIT = 2
Lcdinit 1
Dim a As Byte
Dim b As Byte
Dim c As Byte
Dim d As Byte
Dim e As Byte
Dim f As Byte
Dim g As Byte
Dim h As Byte
Dim i As Byte
Dim j As Byte
Dim k As Byte
Dim l As Byte
Dim m As Byte
a = 0
b = 0
c = 0
d = 0
e = 0
f = 0
g = 0
h = 0
i = 0
j = 0
k = 0
l = 0
m = 0
Lcdout "coded lock"
Lcdcmdout LcdLine2Home
Lcdout "waiting..."
WaitMs 1000
WaitMs 1000
starter:
If PINA.1 = 1 Then Gosub inc
If PINA.2 = 1 Then Gosub dec
If PINA.3 = 1 Then Gosub enta
If PINA.4 = 1 Then Gosub show
Goto starter
End
inc:
Lcdcmdout LcdLine2Clear
If a < 10 Then
a = a + 1
'b = b + 1
Lcdout "number=", #a
Else
a = 0
Endif
Return
dec:
If a > 1 Then
a = a - 1
'b = b - 1
Else
a = 10
Endif
Return
enta:
e = e + 1
If e = 1 Then
Write c, a
Read c, d
Lcdout "stored ", #d
Else
If e = 2 Then
Write f, a
Read f, b
Lcdout "stored ", #b
Else
If e = 3 Then
Write g, a
Read g, l
Lcdout "stored", #l
Else
If e = 4 Then
Write h, a
Read h, m
Lcdout "stored", #m
Endif
Endif
Endif
Endif
Return
show:
'Lcdout "processing"
'read:
Read c, d
Read f, b
Read g, l
Read h, m
Lcdout "code = ", #d, #b, #l, #m
WaitMs 1000
WaitMs 1000
WaitMs 1000
'Lcdcmdout LcdLine2Home
'Lcdout "code 2= ", #b
'Lcdout "code 3= ", #l
'Lcdout "code 4= ", #m
Return
