crille
Newbie level 2
Hi
I have done a schematic and pcb, and when i run the design rule check I got this warning "Minimum Solder Mask Sliver Constraint Violation".
I know I got this warning because it's only 0.047mm between solder mask on pins on my ATMega644P footprint (44ML_N) from atmels library.
The PCB manufacture has statet 2mil (0.0508mm) minimum for Solder Mask Sliver Constraint, which I have added to the rules .
I can not move the solder masks because the pin's on the ATMega is so close to each other.
Any tips how I can solve this problem?
Thanks
Thanks
