Sep 20, 2010 #1 R rocky79 Member level 5 Joined Sep 20, 2010 Messages 83 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,903 Hello, Is there an option in Altium designer 6 to turn off the soldermask on a copper pour? I am trying to make a heat sink pad without a solder mask. For some reason the tenting option that you normally see for a pad is not available for copper pour. Thanks in advance
Sep 21, 2010 #2 A Anonymous_Ricky Advanced Member level 2 Joined Dec 26, 2006 Messages 516 Helped 88 Reputation 178 Reaction score 58 Trophy points 1,308 Location India Activity points 3,974 you can draw/copy a similar area as your copper pour in solder mask layer so end result will be that cu area exposed.
Sep 21, 2010 #3 R rocky79 Member level 5 Joined Sep 20, 2010 Messages 83 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,903 Thank you, that helped
