Alternate software to (rs485 terminal) Docklight software in linux.
rangerskm
Full Member level 4
Full Member level 4
I Want to read data from a sensor which has RS485 interface .As the computer has only usb port ,I used RS485 to usb converter.In windows i am getting the response data when i send request data.When using in linux i tried minicom software ,but I am not getting the response data when i send request data.
It shows the ftdi driver for the converter.
i need to clarify is the problem with ftdi driver or minicom ?
do I need to change any setting in the driver as minicom settings ?
Here is worked example where we send and read data from ModBus Energy Meter using USB<>RS485 adapter:
Hope this help you.
Regards
KMtonic
