fanwel
Full Member level 3
Hi all;
I have previous problem that still cannot solve. I have try to use the new version of quartus2 but the internal error still occur.
I also have try to delete the db and db_increment directory but still not work. The compilation is work for the first time, before I turn on the Generate Value Change Dump File Script option (Assignments>Settings). Below is my code and the internal error:
library ieee;
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
package my_data_types is
type sfixed_array_t is array (0 to 3) of sfixed (9 downto -8);
end my_data_types;
library ieee;
use work.my_data_types.all;
entity reg_one is
port (clk: in bit;
Ra: in sfixed_array_t;
out_Ra: out sfixed_array_t);
end reg_one;
architecture reg_one of reg_one is
begin
process(clk)
begin
if (clk'event and clk='1') then
for i in 0 to 3 loop
out_Ra(i) <= Ra(i) after 10ns;
end loop;
end if;
end process;
end reg_one;
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 514
m_port_info.num_of_dimensions() == 1
Stack Trace:
0x251D8 : WSC_PORT::bus_member_index + 0x88 (NETO_WSC)
End-trace
Quartus II Version 8.1 Build 163 10/28/2008 SJ Web Edition
Can anyone helps me please..really need helps. Thanks
library ieee;
end my_data_types;
library ieee;
entity reg_one is
port (clk: in bit;
end reg_one;
begin
process(clk)
begin
end loop;
end if;
end process;
end reg_one;
Stack Trace:
End-trace
