altera global clock division
bbgil
Full Member level 2
I'm trying to use the global clock setting of altera Max 7000s but it is too fast for my design. How do i slow it down? do i need to put a clock division program in my architecture? If so, can anybody help me? I'm modelling a project based on a 2 Hz clock system. Thanks in advance.
@ltera global clock division
what is an input frequency? and what is you desired frequency?
my input frequency is the global clock setting of Max 7000s (24.5 MHz). i tried using decoder to slow it down but i'm having problem on the vhdl architecture part coz its requires longer programming. my desired frequency is 2 - 5 Hz. thanks for any input.
maybe you can use clock setting to get your clock tree in quartus,at first you set an individual clock as a base clock, and then you generate the derived clock from the base clock,good luck
What was wrong to impliment simple counter?
i think u can use exterior clock generated by youself.i suggest y don't use dividor to u design.division maybe generate lots of question.
this is clock division i always use to obtain slower clk..
If you need a slower clock, here is a simple clock divider algorithm, that divides the clock by 2N.
Where :
N = F(crystal) / 2* F(desired)
-- file "clk_div.vhd"
-- a generic clock divider, divides by 2*N
-- adapted from "VHDLL Primer" by J. Bhasker, p. 295
library ieee;
use ieee.std_logic_1164.all;
entity clk_div is
generic(N: positive:= 2);
port
(fast_clk, reset: in std_logic;
slow_clk: buffer std_logic
end clk_div;
architecture behavioural of clk_div is
begin
process(reset, fast_clk)
variable count: natural;
begin
if reset = '1' then
count := 0;
slow_clk <= '0';
elsif rising_edge(fast_clk) then
count := count + 1;
if count = N then
slow_clk <= not slow_clk;
count := 0;
end if;
end if;
end process;
end behavioural;
preferably, use macros provided in quartus itself. it ll save a lot of resources.
